Thread: Relocating an EAB During Phase 1
    What are the rules of engagement if it necessary to move an EAB aircraft outside of its designated operating area prior to the completion of Phase 1?
    Is it as simple as applying for special ferry permit?
    Do the circumstances such as evacuating due to a natural disaster vs say a sale or job transfer influence the ROEs?
    Contact the FSDO. Getting new operating limitations specifying a new test area is straightforward, no problem if you can trailer it there. I've done that for purchased homebuilts that I wanted to put back into phase 1 for major changes. Flying it there, I dunno... either way, the FSDO will know.
    melann's Avatar
    Jul 2019
    N. Texas, Dallas Area
    The local FSDO or a DAR can amend your operating limitations. If the new location is within a couple hundred miles, you may be able to negotiate a one time flight to the new area depending on what point in Phase I you are.
    Feb 2019
    I tried for a ferry permit before Phase 1 was completed, and was told “We don’t [or it could have been can’t] do that.
    It makes sense not to allow it in most cases. An amended test area could make sense, if part of the new area overlapped the original area, thus not requiring a ferry permit.
    BJC
    Jackson MS
    I asked my local FSDO about it a couple of years ago, when I was considering an RV that was still in phase one. They responded within a few days, saying that they would issue a ferry permit as long as the plane had a few hours on it to be sure there were no major issues. I never had a chance to put it to the test; the builder sold it to another person before I got the OK.
    As most of us know, this kind of stuff is unfortunately highly dependent on *your* FSDO, unless you can show them chapter & verse in the regs. With some, even then....
    Charlie
