Thread: Jodel D11 sky princess project
    Sep 2020
    Has anyone built the sky princess variant? Basically the cabin is widened by 2” and the seat is moved back 2”.
    I want a homebuilt that on completion will qualify as a light sport aircraft. I will NEVER carry passengers as the wooden homebuilt a are just too tight.
    The sky princess is a little heavy but I think that the rules will have changed by the time I complete the project.
    Here are the specifications from Graham Clark. He took over from Frank Rogers who originally put the plans out to the Australian market.
    SKY PRINCESS
    The Sky Princess is a locally (Australia) developed, side-by-side wooden aircraft based on the Jodel D11 but incorporating several desirable improved features. As it is structurally and aerodynamically similar to the D11, this description covers areas where differences occur.
    The cabin width is increased to 44" and the seat back moved 2" further aft for better comfort. The firewall width is increased, enabling a wider but narrower 13 Imperial gallon fuel tank to be fitted, thus giving greater room between the tank and instrument panel. The instrument panel is hinged for accessibility during maintenance. Aft of the seat, below the upper longeron is a large capacity baggage locker accessible from the cabin.
    The wing incorporates a strengthened main spar enabling the main undercarriage track to be increased to 8' 6" for even better ground handling. Provision is made for two optional 5.5 Imperial gallon (25 litre) wing tanks,.
    The cabin doors are hinged on the windscreen bow, but a sliding canopy can be fitted if desired. To compensate for torque, the engine is offset 1.5 degrees. Engines of from 100 to 118 hp may be fitted.
    Specifications with a 100 hp Continental O-200 engine.
    Span 26' 9"
    Length 21' 5"
    Wing Area 137 ft²
    Weight Empty 860 lb
    Weight Loaded 1,450 lb
    Wing Loading 10.6 lb/ft²
    Max Speed 135 mph
    Cruise speed 120 mph
    Stall Speed 35 mph
    Climb 800 fpm
    Range 560 miles
    Sport Association of Australia Plans No 56
    The useful load is 590 pounds. Standard fuel load is 13 us gallons. Add in the optional tanks and it comes in at 24 gal. With full fuel that still leaves 446 pounds for carrying big guy (me) plus some luggage in the aft compartment.
    Any other suggestions or alternative choices for wooden homebuilts?
    (I really considered a Pietenpol but I just can’t see how I could make the cockpit a usable size. The fly baby isn’t an option for payload reasons.)
    I wrote the builder of the following project to get the details of his cockpit tweaking. Search for Jodel Diesel and you can see the plane in flight.
    http://www.aviationnews.co.nz/news/1...y-s-new-Jodel/
    Thanks again for reading my post and offering feedback.
    Sep 2020
    I just pulled the trigger for a set of plans.....
    Sep 2020
    Plans are in transit.
    Quote Originally Posted by VikingCNP View Post
    Weight Empty: 860 lb
    Weight Loaded: 1,450 lb
    By the Oz specs, the plane is too heavy for Light Sport: 1,450 lbs, vs. the 1,320 lb Light Sport Limit.
    No matter, though: When you apply for the US airworthiness certificate, just list 1,320 as the gross weight. The manufacturer (you) sets the gross weight, so it's legal.
    If you don't intend to carry passengers, why bother with the two-inch-wider Sky Princess variant of the D11? If you build the standard version and put the (single) seat in the middle of the fuselage, you'll have scads of room. Or just leave the Pax seat off and you'll have lots of elbow space to the right.
    Sep 2020
    At 6’5” I want the extra headroom. Charles Kenny from New Zealand tipped the seat back to 25 degrees and this gave 6 inches of head room for a 6 foot pilot.
    I have really broad shoulders so that tipped the decision for the wider fuselage.
