Results 11 to 19 of 19
Thread: Best Paint Scheme?
    BusyLittleShop's Avatar
    Apr 2019
    Sacramento California
    I'm a strong believer in preserving the scheme that honors the history of the WarBird as far as can be known... I advocate keeping the scheme and change the WarBird if you don't like it...
    Quote Originally Posted by BusyLittleShop View Post
    Few warbirds have any combat history behind them. Those that saw combat were usually scrapped overseas rather than bringing them back to the US. The exceptions, like Memphis Belle, are locked into museums. So, if one reproduces a typical warbird's actual wartime markings, they'll probably be kind of plain Jane.
    So... why not duplicate the markings of famous aircraft?
    The other factor is having your warbird stand out from the crowd. There are over 600 T-6/SNJ aircraft on the FAA registry. Surely, if the owner of S/N 75-3473 does WANT to be one of the ~50 aircraft with Kelly Field markings, he or she should be able to opt for duplicating the markings of a more unusual example?
    Discussion on this thread has exposed yet another of my misconceptions. Can someone explain the difference between "flat" paint and "matte" paint? I've always used the terms interchangeably.
    Ron "Flat wrong" Wanttaja
    Omro, WI
    I still find it hard in my mind to classify T-6's as Warbirds. Yes, they were used to train our pilots during war, but they were not really a combat aircraft. And when I think of Warbird, I thing of combat aircraft, or at least used on the battle field. But that is just my humble opinion.
    Kurt
    Guess it doesn’t help when some vendors use flat/matte as a sheen and others use flat and matte as separate sheens. The way I understand it that flat has high porosity and therefore is less reflective. Matte has a somewhat less porous texture, therefore has some reflectivity. Not being a paint expert; not sure that the rule of thumb holds true for all types of paint.
    Quote Originally Posted by krw920 View Post
    Kurt
    You should lookup the history of the T-6. They have seen combat action by a number of governments and were used as FAC aircraft by the US in Korea and even early Vietnam.
    Mayhemxpc's Avatar
    Manassas, Virginia
    I had to check that out. Quite a few of the "combat" airplanes in the WoA registry actually served in combat. (Airplanes beginning with A, B, C, F, O, and P, and Navy equivalents.) Most of the B's (B-25s...none of the B-17s), maybe 1/3 of the C's, 3 of the 4 O-2's and about 1/3 of the F and Ps. (Only 1 of the L's). I am assuming that if the airplane's description/narrative does not include combat assignment, then it didn't serve in combat.
    As for mine, I am fortunate enough to have several different pictures of my plane in SEA (in different paint schemes!)
    Chris Mayer
    N424AF
    www.o2cricket.com
    Omro, WI
    I did look them up and did see that, but still is a stretch to me to consider all T-6's combat aircraft when only a handful were used as FAC by the US military. But again, that is my opinion only.
    Apr 2019
    Would the real big Beautiful Doll please stand up...
