Results 1 to 7 of 7
Thread: Best training for converting 3 views into models, either solids or mesh
    Oct 2018
    Hello, I've used solidworks a lot for my machining hobby, but when it comes to taking 3 views and wanting to create realistic models in Solidworks or even Fusion360, it is something I have little experience with. I've mostly used CAD for mechanical engineering.
    One of my hobbies is R/C airplanes and I want to 3D print(another hobby) molds for fiberglass/carbon fiber layup. Easy to design the mold once you have the aircraft modeled up. Maybe one day I'll carry this over to 1:1, but I get enough of that from work!
    Anyone know of a good book, training series, etc for doing this?
    Jan 2014
    Quote Originally Posted by WJH View Post
    Are you talking about building a sketch and model from a photo? If so, we have a basic tutorial on that here (Tutorial - Modeling an Exhaust Fairing): http://eaa.org/swu
    You may also be interested in following Eric Haddad's YouTube Channel for 3D-printed RD models: https://www.youtube.com/channel/UCeo...kakABBJChjSn-A
    Eric is one of our support volunteers that DS SolidWorks sponsors and they encouraged him to connect with us. Interestingly, he has modeled two 3D-printed RC aircraft that are based on unique aircraft from the EAA Museum (Phil Lockwood's AirCam that flew the Amazon for National Geographic, and Art Scholl's original Super Chipmunk).
    Oct 2018
    Quote Originally Posted by Cory Puuri View Post
    Taking a standard 3-view and creating a model from it. Think I found what I was looking for. Going to start off small and make some 3D printed molds for flight control surfaces for my current R/C fleet before I make a giant scale F5 Tiger
    Jan 2014
    Is this more helpful: https://help.solidworks.com/2016/eng...w_document.htm
    vondeliusc's Avatar
    Kalispell, MT
    Nameless WJH:
    Here is an example I randomly created using data from this webpage:
    in section III A.
    https://www.researchgate.net/publica...ssion_analysis
    JPG of SW model:
    Name:  3-view model.jpg
    I just looked for a 3-view drawing example which one is in this document with some dims.
    I entered the side view of the drawing on the R plane and scaled by known dims.
    I copied the scale of the sketch pic to apply to the other views.
    I put the top view (scaled the same) on the T plane.
    I put the front view on the F plane.
    Then it is a complicated effort of extrusions and lofts, capturing the data via sketches at various planes.
    Knowing the design data like airfoils and things helps, but for an approximation, you can get a pretty
    reasonable model if you take the time.
    Here is a link to the model I made for study:
    https://drive.google.com/file/d/10Ud...ew?usp=sharing
    As you investigate my model and feature tree steps hopefully you will get an idea.
    Tip: View from F, R, T and you will see how the sketch photo aligns to actual real life dimensions.
    -Christian von Delius
    Kalispell, MT EAA102
    Oct 2016
    Bend, OR.
    Here is link to an old post that has a little more detailed example:
    https://eaaforums.org/showthread.php...5172#post65172
    Mar 2020
    Cory -
    Can you post what you found?
