That, sir, was an excellent 2,400th post. Hilarious!
Eric Page
Map of Landings
Ron, I was working for a JPL contractor (Bendix Field Engineering) at the Goldstone DSIF Echo Station in the MDE (Mission Dependent Equipment) areas for both Lunar Orbiter (Boeing) and Surveyor (Hughes Aircraft) at the time. We were 'over the moon' after that "Earthrise" image was processed.
Attached is a graphic showing the geometric perspective of Lunar Orbiter 1, Earth and the moon when that photo was taken.
Echo Station in 1967 with my new '65 Mustang.
EDIT - @FlyingRon That heavy boots piece is a hoot!
Last edited by Scooper; 08-01-2020 at 07:06 PM. Reason: Higher resolution pdf image
- Stan Cooper (K4DRD), Private Pilot ASEL, LSR-I, EAA 115792 Lifetime Member, EAA Chapter 124Experimental AMD CH601XLi-B, N601KE, KSTS
Ron. Awesome story. Thanks for sharing.
I was tickled by Stan's story. Amazing there are still folks around who worked the program.
