Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 54th Anniversary of the Launch of the First Lunar Orbiter
    Eric Page's Avatar
    Toledo, WA
    That, sir, was an excellent 2,400th post. Hilarious!
    Eric Page
    Map of Landings
    Scooper's Avatar
    Jul 2016
    Santa Rosa, CA
    Ron, I was working for a JPL contractor (Bendix Field Engineering) at the Goldstone DSIF Echo Station in the MDE (Mission Dependent Equipment) areas for both Lunar Orbiter (Boeing) and Surveyor (Hughes Aircraft) at the time. We were 'over the moon' after that "Earthrise" image was processed.
    Attached is a graphic showing the geometric perspective of Lunar Orbiter 1, Earth and the moon when that photo was taken.
    Echo Station in 1967 with my new '65 Mustang.
    EDIT - @FlyingRon That heavy boots piece is a hoot!
    Last edited by Scooper; 08-01-2020 at 07:06 PM. Reason: Higher resolution pdf image
    - Stan Cooper (K4DRD), Private Pilot ASEL, LSR-I, EAA 115792 Lifetime Member, EAA Chapter 124
    Experimental AMD CH601XLi-B, N601KE, KSTS
    Mayhemxpc's Avatar
    Manassas, Virginia
    Ron. Awesome story. Thanks for sharing.
    Chris Mayer
    N424AF
    www.o2cricket.com
    I was tickled by Stan's story. Amazing there are still folks around who worked the program.
