Thread: Solidworks Newbie Questions
    Jun 2020
    Solidworks Newbie Questions-sheet metal unbending question
    Hi all
    I`m familiarizing myself with the sheet metal part of Solidworks
    I made a test part thats 100mm wide and 50mm high ...extruded it....then added a 15mm flange....then flattened the part
    question....the 2 lines at the radius....I`m assuming that is the bend allowance?..if so that's nice to know but does the software have other helpful tools to recreate that bend in the real world at the bending brake?
    Can the software add the sight line/other assistance to the human fabricator....or do I have to work that out and add that line myself? I'm trying to find out how far the software goes after the flatten command...if what I see here is as far as it goes and i work it out from there
    Thanks
    Michael
    vondeliusc's Avatar
    Kalispell, MT
    SW sheet metal behaviour
    Michael-
    I am not sure why you have two lines displayed; the only way I could generate that was to 'force' unfold it.
    Normally, you just use the flatten button in the model, or select the 'flat pattern' in the view selection.
    The indicated bend line is the middle of the bend, or center of the bend allowance, and shows the bend radius,
    the angle to bend and up/down.
    The two lines you show IS the bend allowance distance.
    As far as the sight line, you would have to add that in.
    My drawing shows a 50mm long with 15mm flange at 1mm thick with 1mm BR and .5 K-factor.
    I plasma cut parts and use the bend center dimension to bend parts accurately.
    -Christian
    Jun 2020
    Quote Originally Posted by vondeliusc View Post
    Michael-
    -Christian
    Thank you for reply
    oooppss, I just realized I used the unbend curve command not the flatten part command. I think that's why it showed those 2 lines on my part rather then the single line of the centre of the radius as you describe.
    its great that you can zoom in on the part you attached, you can really see what's going in the radius.
    ill print some sample bend patterns and tack them on the aluminum and do some trial bends
    thanks
    Michael
