Results 11 to 12 of 12
Thread: I need some help with longerons
    Jun 2020
    Quote Originally Posted by vondeliusc View Post
    Brian-
    Yup, you probably will need to break them to about 6' for cheap shipping. I would suggest at least an inch extra since most cuts by sellers are dubiously accurate.
    Also, since you have a model, you can pick where you want the joints to be. Using 0.049, inner sleeving will be a bit sloppy; if you use 0.058 as an outer sleeve,
    it will sleeve snugly over the next 1/8" size down (0.875 x 0.058 over 0.75) and I would guess about 2-3 tubing diameters each side for the sleeve (say 6").
    There was no attachment to the post, btw, because I would have liked to take a look.
    -Christian
    sorry I don't know how to get the file small enough to attach here
    vondeliusc's Avatar
    Kalispell, MT
    Brian-
    You can save the file(s) to Google Drive, DropBox, or OneDrive and share the link here.
    -Christian
