Originally Posted by
vondeliusc
Brian-
Yup, you probably will need to break them to about 6' for cheap shipping. I would suggest at least an inch extra since most cuts by sellers are dubiously accurate.
Also, since you have a model, you can pick where you want the joints to be. Using 0.049, inner sleeving will be a bit sloppy; if you use 0.058 as an outer sleeve,
it will sleeve snugly over the next 1/8" size down (0.875 x 0.058 over 0.75) and I would guess about 2-3 tubing diameters each side for the sleeve (say 6").
There was no attachment to the post, btw, because I would have liked to take a look.
-Christian
