Thread: Very Slow Loading of Assemblies
    May 2020
    Hi All,
    I'm using SW Student 2019 downloaded in Dec 2019.
    Parts load from memory very quickly.
    Assemblies take a very long time (3 to 15 minutes) even for super simple two part assemblies.
    If I open the component parts first, then open the assembly it opens very quickly. But if I try to open the assembly directly it takes forever to open and seems to get stuck on opening part 1.
    Any help would be richly appreciated.
    Thank you
    Maze
    May 2020
    Resolved.
    I seem to have fixed this issue. I opened the Options tab and reset all the options to default. Then hit save. It prompted if I wanted to allow changes to be made, I hit yes.
    Is is now working properly again.
    Thank you
    Maze
    vondeliusc's Avatar
    Kalispell, MT
    Quote Originally Posted by Maze View Post
    Hi All,
    Thank you
    Maze
    Maze-
    not completely applicable, but if you open 'lightweight', you still have visuals on parts you are not using, and can 'set to resolved' if you need to edit something, which is helpful for large assys and/or slow computers.
    -Christian
