Results 1 to 7 of 7
Thread: SolidWorks license & version changes...
    Jan 2014
    I am the "expert" on the license. You can download the software and you get 12 months of use from the day you activate it with a serial number over the SOLIDWORKS servers. You must activate the software before June of each year or the serial number will not be valid. If you want to install now and then upgrade to 2020, you will need to install 2019, activate it and do a full uninstall (before you click the confirmation to uninstall, click CHANGE next to Advance and checking all boxes to remove the 2019 serial number from your Windows Registry). Then, install and activate 2020.
    In case you forget to do a clean uninstall, the uninstall instructions are included with the 2020 installation instructions.
    May 2020
    Cory,
    I completed the SW install on 5/7 but the activation shows it expires 12/31/2020. Is this correct or will I need to reactivate it in December to get the remaining months? I understood the license to be good for 1 year. I'm a current SW user at the company I work for so I understand the SW installation/activation. I also handle the SW deployments for the yearly upgrades. We use a network license so maybe the licensing structure is different.
    I also sent you a PM on the subject.
    May 2020
    I assume Cory's tied up on other projects so while I'm waiting for him to see my original message, has anyone else ran into this where the activation says it expires at the end of the year rather than 12 months from the activation date? Just curious.
    Thank you
    Quote Originally Posted by actruck View Post
    Cory,
    Jun 2020
    My 2019 version also says it expires at the end of 2020 even though I got it in March of 2020. I tried to download the Solidworks 2020 installation package but it said this was not compatible with my license. Can I buy the 2020-2021 student version for $99 and have it work with my EAA student license?
