Hi, Folks; I'm in need of some avionics help with wiring my comm headset/mic jacks. I KNOW how to differentiate tip, ring, and common on both, and how to read on a schematic, but this is more of an implementation question. Some schematics have the PTT wired to the tip connection on the mic jack. Others just have the PTT connect directly from the switch to the edge connector on the harness. Electrically, they're almost the same. BUT, my question is....if I wire directly, bypassing the mic jack, does that do anything signal-wise like eliminate the side tone, or am I good to just wire from the stick to the harness, without connecting to the mic jack?
