You might try Lexan (polycarbonate). The thin stuff, .030" , is very flexible and easier to cut and drill than plex. No molds, no oven needed. You can buy it locally or order it from companies like eplastics.com
Tralika,
So you just hand bend and screw it down? I may try that too.
Some of the discussion on VAF was about cutting a flange so the lens can fit flush, apparently inserted from behind. How is then lens then attached to the LE?
I had figured I would just make an aluminum frame, with a spacer so the 1/8 lens will fit flush with the .032 skin. Flush rivet it around the circumference of the LE cutout. Nutplates behind the frame. Then screw down the lens to the frame. Not an especially clean result though...
You don't have to attach the lens to the leading edge, as you sussed out, you make a frame for it with nut plates.
Here's how they did it for Cubs and other Pipers - make a false nose rib, and attach it to the spar the length of the light fixture away from a true rib. Rivet a half inch wide strip along both (.020 works great), and then tag another across top and bottom. You can cheat some strength in there by placing K1000 nut plates in the corners where each ear is on a different part, too. Also, cut two pieces of aluminum sheet that match the the airfoil of the nose rib and, after painting black, rivet to the sides of the ribs to keep the light out of the wings and going forward.
The real stunt is making the measurements to cut out the light fixture hole in the leading edge material. One wants to be shy to the fixture, as it's always easier to cut more off of a hole.
(I had to do this at work last month)
Mike, Frank,
Thanks much! I may quarantine myself in my hangar and get this done.
