Thread: Compatible CAM Extensions for Solidworks
    May 2015
    Now that I have some experience with SW, I need to create toolpaths for CNC machining (milling). Are there any CAM modules that integration with SW and allow for an easy learning curve? All suggestions are appreciated!
    Jan 2014
    2.5-axis CAM is built into SOLIDWORKS. Are you running SOLIDWORKS Education Premium 2019-2020? If so, you can open that module following these instructions: https://youtu.be/Dti5zbcJ5fI
    May 2015
    Thank you Cory. I found the add-in that you mentioned and learning how to use it. I am also trying out the BobCAD-CAM 3-axis Solidworks add-in. Very powerful tools - I hope that the partnership between EAA and Solidworks will be ongoing, it is certainly a valuable benefit. --Rob
