Results 1 to 4 of 4
Thread: Is this legal?
    Merrll WI
    It is the other way around . Part 43 reg states to route electrical wire above fuel and oil lines. so in case there is a leak. Fuel or oil does not drip down on electrical wiring. I think if you have the electrical wire on top and covered you will be in the sprite of the Reg.
    CarlOrton's Avatar
    DFW Area
    Yeah, I know I stated it incorrectly. Was merely trying to say I had read and understood the AC. My electrical is routed completely removed from any fuel line. Just didn’t know if a nylon line could be paired with another thru one grommet or if separate grommets were required.
    Carl Orton
    http://mykitlog.com/corton
