Weldment Profiles - not loading properly in Solidworks 2019-2020
Hi All - I'm having an issue getting Weldments profiles loaded in SW 2019. I've read about a dozen articles on how to do this - and it's not complicated, but it just wont work for me. Any suggestions would be appreciated.
Here is what I've done so far:
1) Gone to Design Library / Solidowrks Content / Weldments - and then downloaded the ANSI Inch profiles.
2) Unzipped these profiles and placed into the proper Solidworks directory (as indicated by Options/ file locations / Weldments)
The results are:
I can see the profiles when using Weldments but only partially: I see the "Standard" (ANSI Inch), and I see the "Type" (specific profile), but I do not see the "size" as an option.
I've tried creating folders to represent the right structure, etc... but nothing works. It appears that the pre-loaded profiles all have multiple size configurations built into the profile sketch (ex. I-beam has 3 sizes). But the additional profiles I loaded are only 1 size each (a separate sketch for each size). However, these profiles weer loaded directly from the Solidworks Reference Library - so I'd think they should work?
Any ideas would be appreciated...
Thanks
