Results 1 to 10 of 11
Thread: Help me Find This Bolt!!
    Brrrmidji , Minne-SNOW-ta
    Yeah , knot sure why you're trying to match the head of the bolt ...
    Write to the ARMY or NAVY (A/N) to sea if they can give you a revision number to update your hardware .
    Gotta cross those eyes and dot those T's...
    They are having a SALE on Red Tape...
    Folks: THANK YOU very much for responding for my request! Yes, I know it is a AN 4 bolt by design, BUT I do, in fact, need at least ONE with the EXACT head logo. I am restoring an American 60’s sports car for a fellow, and the car maker took advantage of as many surplus military fasteners as possible. Obviously, that was wise financially and structurally, because the fasteners were sold by the pound, and were very high quality. This particular AN4 Bolt is one of four used to attach the front bumper to the car. Unfortunately, one is missing, so this answers why I’m looking for an old aircraft quality bolt. There is no hole drilled in the head or the threaded shaft. I found the link provided by one responder very interesting! Although the link did not source the bolt, it at least confirmed it to be made for aircraft application. I hope this clarifies why I’m searching for this single item. The bolt appears to be cadmium plated. Any additional help would sure be appreciated! Best!! Bob
    Apr 2017
    Is there any reason you can't replace all 4 of the bolts with new AN4 bolts that have the same head marking?
    with a little Molding....use the head ...make a mold of it .epoxy it on the odd bolt ...passes the eye
    better yet ...
    Warm the bolt ... push it into wax....for the mold ....remove.
    Use "High Temp" silicone....put a tiny bit in the mold .
    Put the Blank/oddball bolt into the mold , let set for 24 hrs
    You now have a VULCANIZED RUBBER BOND
    Quote Originally Posted by PNelson View Post
    I suspect he's trying to get the original-style bolts on the car he's restoring. Will get docked points at car shows if it's unoriginal.
    Folks, Ron is correct. In the car world, originality is King! I know it’s different with planes; you replace everything over time, except for the frame and skin, I assume. It’s interesting that out of over 3700 views, no one could apparently source of of these bolts. There has to a tricycle out there somewhere with one of these dad put on to keep the fender in place!
    Thanks to those of you who took time to respond!!
    Best, Bob
    Quote Originally Posted by pistachiobob View Post
    Best, Bob
    No need to keep the frame or skins intact on an airplane. As long as the data plate is intact! And I'm sure you're right, you just need to find that tricycle. I think those are just vintage military surplus bolts, but it's unlikely you'll find a cache of them for sale now. I'm sure tens of thousands still exist, but likely all buried in old airplanes or the occasional car bumper or tricycle.
    I found a couple of the same brand of bolts...but they're AN5. I'll keep looking.
    [edit]
    They came off of a 1946 Cub we're restoring, from the wings.
    [/edit]
