Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
Thread: Now THAT'S a Spinner!
  1. #21
    BusyLittleShop's Avatar
    Apr 2019
    Sacramento California
    A closer look at those bullet defector plates from the Epic of Flight...
    In 1915 from an airfield near Dunkirk, French Lieutenant Roland Garros
    took off armed with defector plates that for a time would make his
    Morane Saulnier the most feared weapon in the air. Before the War
    Garros had won acclaim at international air meets, had set an altitude
    record of more than 18,000 feet and-in 1913- had become the first man
    to fly across the Mediterranean. But his first efforts as a combat
    pilot had netted him nothing. "I was able to outmaneuver my
    adversary," Garros wrote, "but my observer never succeeded in shooting
    him down with the light rifle, carbine or shotgun that constituted our
    armament."
    On a visit to Paris, Garros expressed his frustration to Raymond
    Saulnier, the plane builder. In April of 1914 Saulnier had applied for
    a patent on a cam-operated mechanism that, in theory at least, would
    enable a machine gun to fire cleanly between the blades of a revolving
    propeller. The design was sound enough. Unfortunately, the available
    Hotchkiss machine gun tended to fire at an uneven rate and the
    ammunition it used produced a high proportion of delayed " hang-fire"
    rounds. No device could keep it from mistiming and shooting up the
    wooden propeller. But Saulnier also showed Garros something else he
    had designed: a steel deflector that, when fastened to the propeller,
    would protect it from damage by the small percentage of bullets that
    might actually hit it. Intrigued, Garros and another friend, master
    mechanic Jules Hue, set to work to test the deflector idea. They
    bolted a gun and engine onto an obsolete plane. I started the
    engine, wrote Hue. "Garros fired and everything collapsed. The
    engine fell to the ground, one blade of the airscrew having flown off,
    and the fuselage broke behind the cockpit. What had happened? One of
    the braces holding the deflectors had broken.
    Hue thereupon fashioned better braces and produced a more streamlined
    set of deflectors: wedge shaped, with gutter-like channels for the
    bullets. In March Garros reappeared at St. Pol airdrome near Dunkirk
    with a Hotchkiss gun on a fixed mount behind the shielded propeller of
    a Morane-Saulnier monoplane, and on April 1 he took off alone toward
    the German lines.
    Officially, his mission was to bomb the railroad station at nearby
    Ostend. But along came a German Albatros, seeking a look at the Allied
    trenches after a week of bad weather. Garros, climbing, bore in on the
    German plane. Then, from just behind his propeller came the orange
    winking, the thin smoke trail, the noisy rattle of a machine gun. The
    surprised Germans fired back with a carbine, but it was no contest.
    Garros furiously slammed fresh ammunition into the gun until, on the
    third clip, "an immense flame burst out of the German motor and
    spread instantly." The Albatros went into a wide spiral and crashed. "I
    gazed below me for a long time," Garros wrote later, "to convince
    myself that it was not a nightmare.
    Never before had a man aimed his entire plane as though it were the
    weapon, and shot through the propeller to bring down an enemy. The
    deflectors might be jury-rigged and imperfect, but they had worked,
    and the prophecy for the future was incalculable. On April 15 Garros,
    again firing through the shielded propeller, shot down a second German
    plane. Early in the morning of April 18 he got his third, making him
    second only to Pegoud, with five.
    But later that very day Garros trumped himself. In the afternoon he
    again took off from Dunkirk, swooped too low behind the enemy lines
    and had his gas line cut by a single bullet fired from the ground.
    After gliding to earth, he tried to set fire to his plane to protect
    the secret of its armament. But he was too slow. German troops
    captured the plane, and Garros, intact.
    The Germans were jubilant over the opportunity to unravel the mystery
    of the French plane that had destroyed three of theirs in less than
    three weeks. Ironically, the technology needed to develop an even more
    sophisticated method of shooting through the propeller was already
    available to them. Franz Schneider, a Swiss engineer working in
    Berlin, had applied for a patent on a synchronizing device even before
    Saulnier had; unlike the French, the Germans had an air-cooled
    Parabellum machine gun that was reliable enough to be adapted to the
    timing mechanism. But Schneider had been given no machine guns to work
    with. Instead, once Garros and his plane were in their hands, German
    authorities assigned another engineer to develop an imitation of the
    captured French device. Meanwhile, Allied airmen continued to dominate
    the sky.
    Enter Fokker and his team and they built a cam-operated push-rod
    control mechanism connecting it to the oil-pump drive of an Oberursel
    engine and the trigger of a Parabellum machine gun. They then attached
    a plywood disc to the Oberursel's propeller and kept test-firing until
    they got an even pattern of bullet holes between the blades. Finally
    they mounted the whole works on the Fokker M.SK and reported to
    Doberitz air base with the world's first reliable single-seated
    fighter plane. The operation had taken, not 48 hours, but several days
    of around-the-clock work.
    From defecting bullets to synchronized forward firing to a mono plane
    sporting enclosed aerodynamic cowl and bullet spinner, all the
    beginnings of a modern fighter...
    Roland Garros...
