Thread: Westfall negative stagger biplane
Threaded View
    Nov 2017
    I discovered Westfall negative stagger biplane in Sport Aviation of october
    and found that this cabin biplane was great, I couldn't resist to draw a
    microlight-LSA variant with a VW 2180 70HP engine
    I took same dimension gap 46" and chord 42".
    Here are some thoughts concerning the biplane with positive and negative
    loads.
    flying wires
    https://drive.google.com/file/d/15HS...ew?usp=sharing
    landing wires
    https://drive.google.com/file/d/1qHR...ew?usp=sharing
    some specs
    https://docs.google.com/spreadsheets...it?usp=sharing
    munk factor
    https://drive.google.com/file/d/1UzD...ew?usp=sharing
    50 ft clearance
    https://drive.google.com/file/d/1baw...ew?usp=sharing
    Take Off ground roll
    Figures could be divided by 2 with a reducted Rotax engine. Static thrust of VW2180 76HP
    is given by Great Plains builder manual 247lbs that is quite anemic.
    Upper spar of cabin to support wing rear upper spar (cantilever)
    https://drive.google.com/file/d/1JlO...ew?usp=sharing
    Upper spar with fixed end moments
    https://drive.google.com/file/d/1BrRtoFC-XNvQJRuCWuc34dmIjQCLApit/view?usp=sharing
    High Definition (300dpi) PNG side view
    https://drive.google.com/file/d/1_ps...ew?usp=sharing
    P.S : I use english and french, but in the latter case I think that drawing would help even if you don't know french.
    This post "Westfall negative stagger biplane" is for educational purposes only and may contain errors. Any attempt
    to use the results for actual design purposes are done at the user's own risk.
