Results 1 to 7 of 7
Thread: Davis DA-11
    Eric Witherspoon's Avatar
    Tucson, AZ
    Davis DA-11
    I've been looking for an article on the Davis DA-11 "Mower Power to the People". I found the DA-9 article in the August 1996 issue, so I believe the DA-11 article would have been after that. I thought the DA-11 was on the cover. Now I'm thinking it was one of the Experimenter magazines when that was printed as a separate publication. Anyone have this, and could scan or photo it for me?
    Along that line - will EAA be scanning the older printed Experimenters as part of the searchable online archive?
    http://www.spoonworld.com
    Just did a quick google search for it and the one page article popped up at AirplaneZone.com. Hope that helps.
    WA
    There was just the one page only in Sport Aviation. Contact magazine did a full article, and I think it was reprinted in the alternative engine book series.
    Tucson, AZ
    Got it. Thanks!
    Jun 2018
    ATL
    I would love to find plans for the DA-11, but my research suggests plans were never sold. What similar all-metal, high speed (90+ kt), low operating cost single seaters would be comparable to the DA-11?
    Looking to buy my first airplane, message me if you have a nice trainer or experimental for sale.
    WA
    Quote Originally Posted by thisadviceisworthles View Post
    Spacek SD-1
    Rutan Quickie one
    M. Columban Luciole*
    *plans not available in US
    Tucson, AZ
    The DA-5A. Plans were not available for quite a while, but are now available again see davisda2.com. I have a set. Some of the pages show 100% size parts, but the duplication process makes them slightly off, so would need to check dimensions and rescale the copies. The brake attachment at the landing gear isn't defined, but I asked on the forum on that site, and they provided the equivalent drawing from the DA-2A.
    If you read the article that I was asking about, there's a significant issue - Davis couldn't kit it way back then because no lawnmower company wants their engines used in airplanes. Also check max pilot weight - might be lower than you need.
    The DA-5A can handle a pilot up to about 205 lb.
    Another option with lots of current builders, completed / project airplanes for sale, and an ongoing source of parts & support is the Onex by Sonex.
