"I personally am not interested in "manned drone", but rather, horizontal "fixed" wing flight with VTOL ability."
So... you want to make an EAB Harrier, but powered by electric motors. Get out the foam, balsa and epoxy and go for it. Send pics of the construction progress. Start with a scale RC craft and take it from there. What's the problem? Other than needing a regulation size dump truck full of $100 bills to fund it of course - lol
In reading all in this discussion, and watching a few videos with music to sleep by while a manned drone flies off with a beautiful model apparently at the controls, I have to ask a question. While building these toys, if certification happens, will the FAA look at engine out performance, glide ratio ( haven t seen one yet with anything to glide on), how about stall spin characteristics ? Is it gonna have a Cirrus type recovery chute ? Yes, new designs will come out, but when you are "killing clouds" and something goes wrong, what will happen ? Sorry, but as a pilot with experiences in the above, gotta ask the question.
Bill Landry
*If* one of these doo-hickeys is ever certified, you can bet the FAA will require some sort of fallback to keep single-string powerplant failures from causing major injuries. If you've got a man-carrying quad-copter, and failure of one motor or rotor puts the thing into an uncontrollable tumble, the FAA isn't going to buy off on it.
It may be an auto-deployed ballistic chute, or it may be (as others have suggested) a degraded-operations mode that allows a safe landing. The latter, for instance, might cut the other side's motor in the case of a motor/rotor failure on a quad-copter, and an overspeed mode on the remaining two that deposits the vehicle on the ground at a reasonable descent rate.
If helicopters couldn't autorotate, the FAA never would have allowed their certification. However, pilots must usually keep to a specific profile to enable safe autorotation...
It would be assumed that these new powered-lift devices would hard-code such profiles so that their operators stay within them.
Ron, I understand helicopters can auto rotate, but the blades on these toys would have to be a lot bigger like a helicopters to develop any lift .
Bill Landry
Yes, I know, but the FAA will require a certified powered-lift vehicle to provide equivalent capability...either in the form of a chute, or in a degradation mode. The helicopter HV diagram above was just showing that conventional rotorcraft have bad corners, too.
New vehicles will have to go through what is now being referred to as "graceful degredation". Earlier Part 23 is "No single failure can be catastrophic." Graceful degredation takes this another step forward with something like: "After a failure, the vehicle must be able to continue safe flight to a landing." Not saying it's not possible, but I don't see a quadcopter being FAA certificable ... hex, octo, etc. is possible.
Just as a note, the current whole aircraft parachutes are not 0/0 chutes. 0/0 chutes are expensive, heavy and impart high loads on the vehicle and its occupants.
