Insallation Problems
I have had to download twice due to corrupt files. After the second download the install failed for the Microsoft SQL Server. I restarted the install and the Electrical portion wouldn't load because it couldn't find the SQL server. I turned off installation of the electrical portion and the rest seemed to load. I looked into downloading SQL Server from Microsoft but the only ones available are either a trial version of a Cloud version for free. Will the Cloud version work? Can I just install the electrical portion?
Did you figure this one out? Here is a video that some felt was helpful: https://www.youtube.com/watch?v=PZPgmtUOoqs
You will only need to place your CAD serial in the 3D Design / SOLIDWORKS fields and the PCB serial in the Electrical / SOLIDWORKS PCB (also, remove the CAM serial if yours carried over from last year's install).
