Thread: Need Guidance
Threaded View
    Need Guidance
    Hi
    I am a hobbyist and am stuck up . I have an appliance which is a “ U” shaped groove . I need to make a positive of it with a couple of grooves for a “O” ring type suction rings.
    I had the part scanned and have the positive for it as an .stl file. Which I have imported to solidworks2012 and is saved as a .sldprt file.( Assembly.1)
    I have designed the negative for the suction ring and this is also saved as .sldprt file.(Assembly.2)
    Please refer to the pictures attached pictures
    My problem:-
    1. When I go to assembly and open both the .sldprt files the feature manager shows both the files are open.
    2. Both the files are fixed
    3. I make one file ( suction ring) as float.
    4. Unable to see the sketch/model(suction ring)
    5. Suction ring designed is in millimeters with a diameter of 3mm while the other part is a of a diameter of 1cm . I have changed the color of the suction ring to dark red but still it is not visible. Can somebody please tell me what Is the issue here.
    6. I need to insert the suction ring part into the positive of the scan so as to get a pitted surface which can be 3D printed to obtain a mould/negative die for the part.(Assembly part representation.3)
    Can somebody guide me. I have solidworks 2012
