Results 1 to 8 of 8
Thread: Crud removal
    May 2012
    Crud removal
    Does anyone know of a good water soluble chemical that will remove years of dirt and oil from the interior of wings and fuselage ?
    geosnooker2000's Avatar
    Apr 2019
    West Tennessee
    Quote Originally Posted by Eric Brown View Post
    Check out Simple Green. I'm not saying that's the answer, but it's worth a look.
    https://en.wikipedia.org/wiki/Simple_Green
    Oct 2014
    Tehachapi, CA
    Quote Originally Posted by geosnooker2000 View Post
    Do NOT use standard Simple Green on aluminum aircraft or aluminum aircraft parts. SG makes "Aircraft Simple Green" which IS safe for aluminum (and composites).
    It depends on what kind of structure, what kind of crud and what degree of disassembly you're willing to undertake to remove the crud.
    May 2012
    I did try some paint stripper on few test spots. It does work. My concern is that the stripper will get into the lap seams and may not completely wash out. Whadda ya guys think ??
    WA
    Phosphoric acid (first step in etch and alodine) will clean up oil film and corrosion and is water flushable.
    Ospho is mostly phosphoric acid. I using it for cleaning rust off the bathtub.
    I would second the recommendation in the other iteration of this discussion for Dawn, or some cheap shampoo - both with a soft bristle brush for washing cars. Both will cut oil, grease and grime gently. Rinse thoroughly, of course, otherwise you'll end up with a sticky film that will attract more dirt.
    .My concern is that the stripper will get into the lap seams and may not completely wash out.
    yes, that happens. Pressure washing helps.
