Results 1 to 4 of 4
Thread: Configurations: Design Tables
    DNytes's Avatar
    Jan 2017
    Would anyone know if the Student Solidworks version can do configuration Design Tables? We are only get the Student Kit; correct?
    Israel
    As far as I know the Design Tables are a standard feature, so you should have it in the Student edition. (I can't check because I have the commercial package.)
    Jeffrey
    DNytes's Avatar
    Jan 2017
    Thanks I guess I just don't know how to configure them since I am novice SW user.
    Israel
    Ok - please try the following:
    Insert>Tables>Design Table
    If the feature is greyed out then you probably don't have it the student edition, but I doubt this is the case.
    In addition there's a tutorial on the subject:
    Help>SolidWorks Tutorials>All Tutorials>Design Tables
    BTW, The topic heading - "Configurations: Design Tables" - is somewhat confusing because these are two different (independant) subjects. Maybe you can tell us what you're trying to do?!
    Hope this helps,
    Jeffrey
