More room, good speed, slightly more fuel burn: http://www.ebay.com/itm/ws/eBayISAPI...m=220906119084
Rutan Aircraft actually had supplemental plans too - and I took over their stock of paper and can supply the rest - Roncz Canard, Hidden bellcranks, rollover structure, long rudders, etc.
Get in touch - David at canardfinder@att.net
Is there any place you can get a totally updated set of full sized paper plans? or are we forced to scrounge around and get a piece here and a piece there?
You'd do much better asking on and frequenting the canard forums. When plans pop up somewhere it usually gets noticed and mentioned. Plus you will meet many with experience and start to understand who can be helpful and who to avoid. There's a lot of good advice out there once you cull through some first time builders and wannabees that can be scary....
This is 258DC, the fellow that wrote you above, knows his stuff. Was suggested way back earlier in this thread.
I can find original plans with original templates (14 of them); get in
touch if you are serious about building... I have all manner of Rutan Aircraft Factory supplemental stuff too.
David Orr - use Canardfinder@att.net
Why would anyone take second generation plans when originals are available?
Beagle
