Thread: Jodel D.11 (aka D11, D-11)
    Jun 2019
    Hi.
    New here. Dreamer, not builder so far.
    What do you all think of building a Jodel D11 with converted Corvair engine (nominally 100hp)? Are there any particular things to watch out for with either the D11 or the Corvair engine or the combination? What about build difficulty and build time? Also, source for plans?
    Thanks.
    Falconar was a source for plans. Unfortunately they are going out of business this month. The website also states that the rights for all Jodel plans are “sale pending”.
    The corvair engine is a good automotive alternative. Keep your engine placement correct for W&B purposes. Build it correctly, use good parts - don’t cheap out.
    The Jodel wing spar has that outer wing dihedral that makes construction more challenging. Also believe that the D11 is a one piece wing, could be wrong on that, but it’s something you should check out...shop space, handling logistics, etc.
    Jun 2019
    Thanks Dave.
    amv8vol's Avatar
    Mar 2012
    Long Island, NY
    [QUOTE=massmanute;75793]Hi.
    Try the Jodel Yahoo group. Plans (In English redrawn by the late Frank Rogers) are avialable for various Jodel models from Grahm Clark. I am bulding a Jodel DR250
    David N
    David North
    N251JD
    Rudder complete
    Tailplane complete
    Bulkheads complete
    Wing ribs complete
    Flaps complete
    Ailerons complete
    False spars complete
    Fuselage Partial
    Spar complete
    Working on trim tab
    http://websites.expercraft.com/dnorth1/
    Sep 2020
    Starting a Jodel D11 sky princess variant. A Corsair engine is on my list. Charlie Kenny flies his Jodel with a Peugeot diesel. Check eurodiesel on you tube.
