I would also suggest that the rise in mechanical failures is because operators are extremely vigilant in the Phase 1 flight test period. Cowls are removed frequently, jam nuts checked, etc. After 40 hours, there is a temptation to button things up and wait to look again until the next oil change or condition inspection. Pending failures that could have been identified and prevented turn into actual failures.
