Results 1 to 10 of 13
Thread: Need obsolete card edge connector
    CarlOrton's Avatar
    DFW Area
    Hi, All;
    I've recently come into an iCom A200 comm unit and tray.
    I need to re-wire it. The current terminals in the molex edge connector are crimp-type, p/n Molex 4366-GL. The usual sources, Mouser, Digikey, Allied, eBay, etc. all say these are NLA.
    Does anyone have any suggestion as to where I might find some terminals, or, alternately, find a new 30-pin connector with solder lugs or some other viable solution?
    Thanks for any input;
    Carl Orton
    http://mykitlog.com/corton
    Justin, Texas
    Carl: Take a look at this and see if it helps: https://www.molex.com/pdm_docs/sd/008030304_sd.pdf
    If that fails and a call to Molex doesn't pan out, new trays are available here: https://www.ameradio.com/product/8087/description.html or here: https://www.theantennafarm.com/catal...a200-tray-2426
    CarlOrton's Avatar
    DFW Area
    Thanks, Craig; good list of the different part numbers for same part except for plating, etc. Unfortunately, they're just about all still "obsolete" and not stocked by anyone. Trays look interesting, and, no, I haven't contacted either of the sellers, but I would ignorantly assume a new connector and terminal pins would be included. *sigh* The search continues...
    Carl Orton
    Jun 2019
    Maynardville, Tennessee
    Hi,
    Try Ebay for Atari edge connectors 30 pin.
    CarlOrton's Avatar
    DFW Area
    Interesting, Dave; thanks for the tip. Unfortunately, only ones on ebay right now are just the plastic shells, no pins. Will keep looking though....
    Carl Orton
    Feb 2017
    northern ill
    this may be the wrong connector but......... i was looking up the rear connector for a"""" icom ac a210""""" , and "aircraft spruce"......came up with this #10-05914 , and the photo looked correct for the install i was looking at ............ ... .. .good luck, good day /rick
    CarlOrton's Avatar
    DFW Area
    Thanks Rick; number of pins is correct but really need to see the other side. What kind of card edge connector do you have on the 210?
    Carl Orton
    Jun 2019
    Name:  edge connector.jpg
Size:  93.9 KBHi, are you sure this isn't your huckelberry? Card Edge Connector Row 30 Pin 3.96mm Pitch 805 Slot Solder PCB 2x15 Socket CP30
    CarlOrton's Avatar
    DFW Area
    Y’know, Rick, I think that will work! I downloaded the 210 install guide, and the diagrams and illustrations look like an exact match except for the 210 not having a wire for panel light. For the price it’s a decen gamble.
    Carl Orton
    CarlOrton's Avatar
    DFW Area
    Quote Originally Posted by davreich View Post
    Dave, that about looks like it. I’m away from the unit for a few days but will check that one as well as the one from spruce.
    Carl Orton
