Thread: 2 cells with tube web internal shear resisting pattern
    Nov 2017
    Hi,
    I didn't know if it was a 3 cells web, you have to make the spar junction with the upper and
    bottom wing surface (or leading edge). What is your opinion about it ?
    I put the .png on homebuiltaircraft and I open a thread on it on the EAA homebuilder corner.
    Figures (formulas) are from Bruhn chapter on torsion.
    Link https://drive.google.com/file/d/1NJW...ew?usp=sharing
    Nov 2017
    Use of the monospar wing, with thin walled closed (birch ) section
    Nov 2017
    Angle of incidence with help from Snorri Gudmundsson book
    https://drive.google.com/file/d/10KD...ew?usp=sharing
    Wing 6G neutral flaps CG 15% Chord
    https://drive.google.com/open?id=1xu...v18l7hkY4TvltM
    Use of virtual work method(dummy loading) for landing gear deflection
    https://drive.google.com/file/d/1eSC...iew?usp=sharin
