Speciality Oscillating Hand Tool (or 90-degree Blade)
I have the pleasure of having to remove a fuel sender from a wing. To do this, I need to cut out the adhesive holding it to the ribs.
I am in the need for a version of a multi-tool (oscillating tool) where the blade is mounted perpendicular to the tool's longitudinal axis. For instance, a typical multi-tool has the blade parallel to this axis. I need a mounting similar to a typical Dremel Rotary tool, where the blade is 90 degrees to the axis. It's just in this case, I don't want a rotational tool such as in a Dremel Rotary; rather, an oscillating tool instead.
Any thoughts where this may be obtained? Alternatively, a worse case would be a hand tool (powered or not) where the blade was angled at 90 degrees from the shaft.
