Results 1 to 10 of 11
Thread: Shooting digital video through propeller
    Lockhart, Texas, United States
    Recently geeks.com had a special on a digital mini-hd video cam for $30. At that price I decided to pick one up to see if I could get some flying video. Next I needed a way to mount it. I found a neat little device called a "Clampette" for about $15.
    Yesterday I flew the pattern a couple times to see if the cam would work out. Unfortunately as is common with CCD devices the prop shows up, in this case as a series of flickering lines.
    Is anyone aware of other affordable miniature video cams where this isn't a problem?
    Here's a link to the video: http://www.ericmarsh.info/Flying_Wit...e_Pattern.html It may look a little odd at times because the camera was not mounted perfectly perpendicularly.
    I've attached photos of the cam and Clampette.
Size:  60.9 KBName:  IMG_2977 8.50.43 PM.JPG
    Northern NJ
    You might be able to just throw a neutral density filter on the front of the lens to correct for the propeller effect. There is a good thread about this on supercub forums
    http://www.supercub.org/forum/showth...ts-perspective
    Interesting. That filter really made a big difference.
    Treetop_Flyer's Avatar
    Wisconsin
    I've heard that you can also reduce the propeller artifacts by increasing the FPS or changing the exposure (if available on your camera). The ND8 affects the exposure by reducing light. I've heard a polarizer also helps.
    Dave Sterling
    1957 PA22-150/160
    N6929D
    Website
    Minnetonka MN
    This might be a way to get a tachometer calibration. I'm sure the frame rate is determined digitally.
    Matt Gonitzke's Avatar
    Wichita, KS
    I think that effect is due to the fact that cheaper cameras use a 'rolling shutter' and therefore distort high-speed objects like propellers. My old Kodak point-and-shoot and my current DSLR don't do this.
    Mill Bay, BC (Vancouver Island)
    Bluring the prop
    I had the same problem with my GoPro Hero. I ended up adapting the case to take a 1.4 Neutral Density filter. This did the trick nicely. I can also use a .8 filter but the effect is not quite as good. Here is a video I did using No filter, and then the l.4 ND filter. In the accompanying notes I also put links to Tim's site and it was his excellent "how-To" that I followed in solving my own problem with the GoPro. I think that link will take you to the site. If not, just type Vimeo, John Veale into your browser and it should take you there.
    Good luck.
    John Veale
    Quote Originally Posted by Eric Marsh View Post
    Excellent.
    And thumbs high on the perfectly coordinated turns, cgaif!
    Co-ordinated turns
    Excellent.
    And here I thought the scenery was what mattered. Guess I will have to continue to pay attention. I must admit though, not all of my turns are co-ordinated that well.
    Thanks for the comments....Video work is time consuming but rather fun to be able to look back at later. Good flying to you.
    John
    GoPro case modification for large 58 mm ND filter
Size:  89.3 KBName:  IMG_0562.jpg
    A couple of pictures here showing the modification to the GoPro Hero video camera housing to accept ND filters. I used the same mounting holes as are used for the lense cover and drilled out a 'step-up' filter adapter to fit. Works great.
    John (cgaif)
