Thread: Air Compressors
    Mike Switzer's Avatar
    Central Illinois
    Air Compressors
    In 1993 I bought the biggest air compressor Craftsman sold, a 5hp 30 gallon single stage. At the time it was the biggest single phase 220 volt compressor you could buy. The tank has developed a pinhole leak & a replacement is no longer available. I was going to buy a 60 or 80 gallon tank for it, then I saw how much that would cost & I started looking at 80 gallon 2 stage compressors. I was considering the Kobalt that Lowes sells for $950 (made by Campbell Hausfeld) then I discovered the pump life rating is only 10,000 hours. Looking at the automotive & shop equipment suppliers there seems to be a wide range of brands (and varying reviews on quality) in the $1000 - $1700 range.
    For those of you that have 2 stage compressors in your shops what brands seem to work good & which ones should I steer clear of? Thanks.
    Justin, Texas
    Mike: 40 hours a week, 52 weeks a year for just under 5 years to get to 10,000 hours..... If you want a real workhorse, 2 stage, then the commercial level IR, Quincy and Champion are the brands to go with. I've got an IR T-30 that was built in '62 that is about to come out of storage, and I can still get parts for it if needed.
    One option for you is to buy a dead compressor off of Craigslist and remount your power unit to it.
    You can also find used 3 phase units fairly cheap at times too, but changing over to a single phase motor is going to be several hundred bucks. If you choose this route, make sure you buy noting bigger than a 7.5 hp unit, or replacement motor and shop wiring are going to eat you alive.
    I have a similar air compressor from the 1970's that developed a leaky tank. Still looking for a tank because the compressor is otherwise still going strong. My 20 y/o C/H upright probably has ~7-8000 hrs and it's giving me trouble. The new "sealed" motor/compressor rigs are annoying loud.
    Don't run away from an industrial compressor with a three phase motor. Just install a VFD and you can do some neat stuff with it.
    Central Illinois
    I went to the local Rural King store today & was looking around (they had a clearance sale & some new guns), They have a 80 gallon Dewalt compressor for $999, more CFM than the Kobalt. Turns out it is made by MAT Industries in Long Grove, IL. The same compressor is sold under a 1/2 dozen different names, including Sanborn. (The painted over ASME tag on the tank says Sanborn on it). Can't find any info on pump life rating though. TP tools has some nice Champions (made by Gardner Denver) but they are a bit more $$.
    I have been looking at Craig's List & local ebay listings but haven't found anything yet that I am interested in. I sure don't want to buy a used tank that may also spring a leak & possibly turn into a bomb.
    Justin, Texas
    [QUOTE=martymayes;74897
    Don't run away from an industrial compressor with a three phase motor. Just install a VFD and you can do some neat stuff with it.[/QUOTE]
    Where you have to be careful about the VFD is sizing and having the available power to run it. Most VFD manufacturers tell you that for compressor usage, the drive needs to be rated to handle 2 to 2.5 times the nameplate hp of the compressor motor. For example. a Spedestar PC1-100 is rated for a 7.5 hp motor, but it pulls 72 amps when running that motor. To hang one in the shop is over a grand, and you would most likely have to add in the cost for an electric unloader so that you could program it to soft start the compress and not exceed the current limitations.
    I had been looking at going the VFD route with my big compressor, but decided to drop less than half the cash and swap it over to a single phase motor and only need a 40 amp circuit.
