Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Stits SA-3A Playboy
    prasmussen's Avatar
    Feb 2012
    2OH8
    Yike!Name:  img20190228_098.jpg
    The journey is the reward.
    Feb 2019
    Happy Landing gears
    Quote Originally Posted by prasmussen View Post
    Brings back memories. We built our own coal fired blast furnace, cut our own gears, did the drilling and grinding, then heated and bent our own gears. The good old days....... Don.
    prasmussen's Avatar
    Feb 2012
    2OH8
    Grove says they will bend aluminum gear to whatever size and "gun barrel" drill the legs to eliminate a brake line. Anyone had experience with them?Name:  Grove Landing Gear.jpg
    Sam Buchanan's Avatar
    KDCU
    The drilled Grove gear has appeared on many RV-8 aircraft.
    Sam Buchanan
    The RV Journal RV-6 build log
    prasmussen's Avatar
    Feb 2012
    2OH8
  6. #16
    Feb 2019
    Attached photo is N8K in early testing before inverted fuel system, new cowl, canopy, and the trademark red and white sunburst paint. Late 1952. Don
  7. #17
    prasmussen's Avatar
    Feb 2012
    2OH8
    Thanks Don! Do you remember if those are Piper cowling latches?
  8. #18
    Feb 2019
    Cowling
    Not sure. When Ray replaced the first cowl nose bowl with the T-Craft nose bowl, I think he went to Dzus fasteners instead. Don
  9. #19
    Feb 2019
    Quote Originally Posted by Snaproll View Post
    After new cowl, paint, canopy, and inverted fuel system... Don
