Revolved Boss Question
The journey continues; starting to work on the Revolved Boss/Base function.
I can define a centerline, I can use sketch to outline a complex cross-section, then use the Revolved Boss to rotate it around the centerline to form a circular object.
Whoops. My sketch was 1/2" too far from the centerline; the diameter of the revolved boss object is an inch too much. The same centerline is used for another object, so I don't want to move it.
Is there an easy way to move the whole sketch closer to the centerline? Hate to have to redefine each individual sketch point's location.
