Results 1 to 10 of 24
Thread: Will a DAR let me tear down and rebuild an unregistered ELSA
    Jul 2014
    Here is the situation. I am looking at a really good deal on an 2-seat "ultralight" that never got an airworthiness or registration. It has no build logs and no way of ever getting registered as-is. However, it is built almost entirely from bolting tubes together (almost no riviting). Would it be reasonable to buy the aircraft, break it down into its original kit form, and then rebuild it with logs? Will this create any problems with a DAR?
    Can't meet the major portion rule required for EAB with disassembly and reassembly.
    Can register it as experimental exhibition as-is.
    Jul 2014
    The kit is approved 51% when delivered from the factory. If I break it down into the basic components as delivered from the factory, shouldn't it still meet the 51% rule?
    I've spent a good deal of time looking into getting a Sport Pilot ticket. As I understand it, the time window for getting a 'fat' ultralight registered as a Light Sport is long gone. I stand gladly willing to be educated and make no claim to being the last word on the subject, but I 'think' you're out of luck on this one.
    You are correct with regard to registering a "fat" ultralight as an ELSA, however, I think the OP is asking if he can disassemble the plane and reassemble it, create a builder log in the process then register the plane as his own EAB aircraft.
    Tralika's Avatar
    Aug 2013
    I would talk to a DAR about it before I plunked down any money. If you get a DAR on board it might work, assuming the aircraft is an approved 51% kit, and no application for registration or AW certificate was ever sent in, and you have the Bill of Sales going back to the factory that martymayes refers to, and the DAR is willing to really stretch the rules which might jeopardize his certificate or at least his relationship with the FAA. It sounds like a long shot to me but you never know.
    Quote Originally Posted by j_omega View Post
    In order to register an EAB built from a NKET approved kit, you will need an FAA bill of sale from the factory for that kit, or from previous owner(s) that completes chain of ownership back to the factory. IOW's you have to show (with appropriate documentation) those parts are in fact from an "approved 51% kit"
    "If more than 50% of your amateur-built aircraft was built from a kit (prefabricated parts), you must also include a kit bill of sale from the kit manufacturer.
    A regular Aircraft Bill of Sale, AC Form 8050-2 is acceptable if the word 'Aircraft' has been marked through and the word 'Kit' entered."
    https://www.faa.gov/licenses_certifi...uilt_aircraft/
