Thread: reattaching wings
    Nov 2018
    reattaching wings
    i have a pober pixi and i had to remove the wings to ship it home. now i'm tring to reattach them and have no idea of the tourqe valves on the main bolts or the correct cable tension. does anyone have the drawings that show or tell you the correct values?
    thanks
    Feb 2013
    Quote Originally Posted by flyerjim View Post
    thanks
    I found this on Aircraft Spruce's website - maybe buying plans would answer your question. Or at least communicate with Acro Sport:
    "An info pack is $10.50, plans are $125.00 and both can be ordered from
    Acro Sport, Inc.
    Box 462
    Hales Corners, WI 53130
    Good luck - I've long been a fan of the Pixie, but I'm way too big for it.
    The plans I have don't have any fastener torque values or cable tension values. I think you'll have to use the range of standard values for bolt and cable size then come up with something that is not too loose and not too tight.
