Results 1 to 10 of 22
Thread: Inter-rib sag reduction
Threaded View
  1. #7
    Oct 2018
    Canada
    The leading edge is attached to the spar and ribs with pulled rivets. I also added aluminum angle to the trailing edge of the sheeting to prevent the fabric from deforming the sheeting:
    Wow that looks great thank you, the angle aluminum reminds me of like.. a stiffened skin structure or something! Did you use rivets to attach the angle aluminum to the skin also?
    Shouldn't need many rivets. I'll leave it to guys like Frank and Joe to give a more-knowledgeable assessment, but it sounds good to me.
    Standard practice on the Fly Baby is to install ~0.025" gutter flashing across the front of all the wing, horizontal stabilizer, and fin. For more of an antique look, Kurt Gruber left it off the vertical tail:
    Oh perfect that doesn't sound too difficult, thank you, and may I ask, is the aluminum sheeting hard to bend by hand? The wing we are trying to make has a different shape at every rib, we are actually trying to make a crude approximation of Albion Bower's Bell Shaped Distribution Wing, if we are able to.
    Oh, I have a picture of the wing shape we are aiming for, it isn't finished yet but should look something like this:
    Thanks for all the help, wow there are a lot of experienced folks here.. I will definitely have a lot more questions once we have started our build if you all wouldn't mind entertaining them!
    Thanks very much
