Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Looking for plans-build suggestions
    Sam Buchanan's Avatar
    KDCU
    One other thought you might check into..... I *think* (and that opens up a can of worms) that you *can* build a Zenith tail-dragger. I believe it has been done in the past. Best bet is to call the factory and ask.
    And, Sam, beauty is in the eye of the beholder. I felt the same way about the Zenith appearance years ago. But now I'm building one (Cruzer). The bigger tail, no slats, and wheel pants kinda smooth things out. I said kinda.
    I could live happily with a Zenith, they are fine airplanes (and look great from the cockpit!).
    Sam Buchanan
    The RV Journal RV-6 build log
    YouTube Channel
    cluttonfred's Avatar
    World traveler
    Frank, given your expressed preferences, medical questions, and limited building experience, I was going to suggest some of the more ultralight-style (Dacron fabric over aluminum tubes) kits, but then I saw that you wanted to keep the initial investment small and pay as you go. In addition to the options you've mentioned you might consider the Corben (not Pober) Junior Ace, a little lighter than Paul P.'s redesign, plans are still available including a trigear option. There is also historical precedent for fully enclosed Corbens as you can see from the second pic below.
Size:  63.8 KB Name:  CorbenJrAce_e2.jpg
    http://www.aceaircraft.com/
    You might also take a look at Leonard Milholland's designs, especially the Cabin Eagle. They are simple planes, well proven, and the Cabin Eagle is simple the latest evolution. With a few fairing strips, a J-3-style cowling, and the right color scheme it could look very classy as well. It's also designed for VW power which can be another way to save money.
Size:  98.4 KB Name:  10750051_409497715872956_8018003200937049343_o.jpg
    http://www.betterhalfvw.com/cabineagle.htm His planes and plans are much better than his awful web site ;-)
    Matthew Long, Editor
    cluttonfred.info
    Many thanks Matthew! Just the sort of alternative I need to consider. I once dropped a vw engine out, disassembled it, sent the heads out and put on new rings. Re-assemled, it ran fine. I will continue to research alternatives. My first homebuilt will likely be my only homebuilt, so I will try to choose wisely.
    I'm building a Wag Aero 2+2; first time builder. It is a big project but i like being able to spend a little at a time and do some trading and such. If you are interested in the entire process, here's my web site with everything since day one.
    Marty
    marty2plus2.com
    World traveler
    Frank, you might also want to check out these clips of the Cabin Eagle prototype.
    https://www.youtube.com/watch?v=C8er2mqM_5I
    https://www.youtube.com/watch?v=Buq5rig5Tos
    cluttonfred.info
  6. #16
    Quote Originally Posted by Martyfeehan View Post
    Marty
    marty2plus2.com
    Hi Marty, I've been looking and learning from your website for a while now! Keep up the good work and looking forward to your next update! Thanks!
