Results 1 to 10 of 15
Thread: Installing a transponder and ADS-B, Instructions?
    I'm looking to buy an airplane and many of the experimental I am looking at do not have transponders or ADS-B (unsurprising). I live in a Mode C veil, so a transponder (and, in a year ADS-B) will be required. I have an extensive electronics background, but I have not worked on airplanes.
    As I evaluate airplanes, I would like to know what I need to do to install a Transponder in an experimental. I am not too worried about installing ABS-B on something with a transponder (because of the uAvionics Skybecon), but I cannot find information on installing a transponder from scratch. Does anyone know a link to instructions or an install video to install a transponder/encoder on a plane that has not had one before?
    CarlOrton's Avatar
    DFW Area
    Hi, This;
    While I don't have either a link to, or the actual instructions, I installed my own transponder in my homebuilt in 2012. It was a microair 2.25" unit. I thought it was simple and straightforward.
    Just connected a data cable from my EFIS to the transponder so the altitude could be provided (along with power) and then antenna cable to a standard rod antenna on the belly.
    Since I'm also under a Mode C veil, I had the local instrument shop guy come to the hangar to do the biennial transponder cert to ensure what the pitot was sensing was what the transponder was reporting.
    I'll install my own on my current build project as well, albeit with ADS-B out, which requires just a bit more stuff like having a WAAS GPS source. Still haven't decided which solution to use in this instance. Still waiting for the $1000 ADS-B transponder in a box solution. ;-)
    Carl Orton
    http://mykitlog.com/corton
    Intstall transponder. Install antenna. Install an altitude encoder (usually a blind encoder). Connect the wires then spend some quality time with an avionics shop for an Appendix E/F check
    cub builder's Avatar
    North Central AR
    I recently replaced the old Terra Transponder in one of my planes with a Sandia Aerospace STX-165. It has the encoder integral to the transponder, so you install power, ground, antenna, and connect a hose to the static port. That's it, unless you add in the overpriced OAT probe. Fits either a 3-1/8 round instrument hole, or can be adapted to fit half width in a standard transponder mounting hole, or custom cut your panel to fit.
    After installation, you need to swing by a radio shop to have the transponder tested for output, frequency and correct altitude reporting. (regular transponder cert).
    The STX165 does give you the option of running a cable to your EFIS to supply it with pressure altitude, or to plug into separate encoder if you want (EFIS Supplying pressure Altitude).
    -Cub Builder
    Feb 2012
    Barrington, IL
    I. Does anyone know a link to instructions or an install video to install a transponder/encoder on a plane that has not had one before?
    AC 43.13-2B - Acceptable Methods, Techniques, and Practices - Aircraft Alterations
    Dec 2018
    Probably not a lot of discussion because it's stone simple. Hookup power, ground and maybe a wire to the dimmer bus. Connect the antenna and you're done. It's a radio, but there's no audio in/out, so way simpler than a comm. The altitude encoder is nine wires (usually labeled A1, A2, A4, B1, B2, B4, C1, C2, C4) that go from the encoder straight to the corresponding terminals on the transponder. Here's a typical schematic:
    Sam Buchanan's Avatar
    KDCU
    Quote Originally Posted by camorton View Post
    The newer digital transponders and encoders are even easier to hook up than that.......only one serial data wire needed to connect the altitude encoder to the transponder instead of all those gray code connections. Gray code equipment still works but is now very old school.
    Sam Buchanan
    The RV Journal RV-6 build log
    YouTube Channel
    Thanks for all of the information. It's good to know that a lack of a transponder is not a dealbreaker. Now I just need to find something with the useable load I want, that is in my price range.
    Dec 2018
    Well the good news is now lots of people are installing ADS-B, so there's a huge glut of older (but still functional) mode A/C transponders on the market. The economics of installing one are questionable since you'll still need to add ADS-B out by 2020, but it's an option if you're on a super tight budget. Cheaper UATs may still hit the market.
    C.
    crusty old aviator's Avatar
    Jun 2012
    You can't get here from there
    It is my understanding that ADS-B OUT can be installed & certified by a part 145 shop, only.
