Thread: Glasair I FT Brake pads
    Does anyone know if I can get the brake pads from Aircraft Spruce?
    Glasair recently sold and now I don't know what the part number is for the brake pads that I use to order from them.
    Thanks
    cub builder's Avatar
    North Central AR
    Chances are that it likely has 5:00x5 Cleveland wheels and brakes. Look at the wheel for the part number, then look up the part number at Aircraft Spruce, and follow that to the Rapco brake Linings. Or go see your local A&P and he can help you look up the correct brakes for it.
    x2. Just find out what brand wheels and brakes are on the plane (I second the most likely is Cleveland) and buy the parts. They are not Glasair specific.
