Results 11 to 12 of 12
Thread: Using solidworks to verify wing egress from basement
    Oct 2018
    Quote Originally Posted by pylon500 View Post
    Was just thinking, if you wanted to be a little 'experimental', maybe a little mod to include flaps on your wings?
    I know, not really needed, but...
    But I think you better model your fuse as well, 'cause I think it's longer than the wingpanels?
    Wonder if anyone has done that before.
    I'm planning to get the whole thing modeled in solidworks. But the fuselage should be easier to fit, as it's only slightly longer, and one end is narrow.
    Not really a trivial task. A second false spar box (similar to that of the aileron) would be needed, and since the flap would probably have more travel than the aileron, it would probably have to be more beefy. Plus you'd need the linkages and controls to MOVE the flaps, and appropriate designing to minimize the potential for a split-flap condition.
    If one were serious about minimizing the chord to support transportation through a restricted stairway, I just wouldn't glue the inner ribs in place. End with the rib on the outer side of the aileron notch. Fit-check the other ribs, but don't glue them together or to the wing. With the outer ribs in place, you can lay out and carve the wingtip bows.
    Then haul the wing upstairs up to the garage, attach the rest of the ribs, and finish the aileron false spar.
