Results 1 to 10 of 12
Thread: Using solidworks to verify wing egress from basement
    Oct 2018
    I've got a basement i'm planning to turn into a workshop for a fly baby. I do want to confirm that I will be able to remove the plane without needing to build egress windows through the foundation.
    The basement has a staircase in the middle, dividing between a finished and unfinished half.
    There are non-bearing walls on the side of the staircase, which I plan to knock down one or both as needed when the wings are complete. If needed, I can remove the stairs as well.
    I'd build a mockup, but then I'd need to knock down the walls, and put them back up, to knock them down again.
    So I build a mock up in solidworks. https://1drv.ms/u/s!An4agHH7T0TFiPIn4MIuLGiXCG9kRQ
    The model has a rough version of the wing, and the basement set up with the walls removed. Once its through the stairs, it's a straight shot.
    Anyone want to give it a go? I never got good at the motion control features.
    cwilliamrose's Avatar
    Nov 2013
    SW Florida
    I'd give it a shot but I don't have 2018 installed.
    Oct 2018
    I updated the file with an e-drawings file as well. Might be a touch more compatible.
    Nov 2013
    SW Florida
    I installed 2018 today.
    It's close according to your models. If they're accurate you should be OK but barely so. There will be a point where the walls and the stairwell will be just about touching the wing in three places. I did the test backwards because it seemed easier starting with the wing in the stairwell and going down. I didn't try it the other way around -- with the root up and the tip down but I doubt that's the best way.
    I had a heck of a time at first because the origin of the wing assembly model was way off the part and doing any rotations will default to the origin as the rotational center. I put the wing assembly into another assembly and put that origin around the center of the wing parts and it was then possible to control the model.
    I did some screen shots.
    Leaving the aileron off should give you some more room.
    Oct 2018
    Thanks! I'll play with it too later on, with a better wing model. That one was just thrown together with some dwg's for the ribs with offsets for the rib caps. I'll go measure some of the critical areas a little more carefully to be sure.
    Oct 2018
    Good point! I'll include that on my more polished model.
    Nov 2013
    SW Florida
    Good point Ron, that will probably take the sweat out of it...
    pylon500's Avatar
    Taree Airport (really) North NSW, Austrlia
    Was just thinking, if you wanted to be a little 'experimental', maybe a little mod to include flaps on your wings?
    I know, not really needed, but...
    But I think you better model your fuse as well, 'cause I think it's longer than the wingpanels?
    Israel
    I also don't have 2018 - could you post a STEP file of the assembly?
