Results 11 to 15 of 15
Thread: Roughness On Run Up
    Yes I could had used a standard massive electrode type of spark plug, that is one that looks like in a car engine. The repair shop had a massive one in stock. and it is about $50 as opposed to $140 for the fine wire one. But I prefer the fine wire type and that is what is recommended for my plane and engine. My plane is turbocharged, I live at 8000 ft and I often fly above 16,000 ft. The fine wires work better at high altitude and they last a lot longer. Even my old ones look old on the outside but the electrodes look almost new after hundreds of hours. So you get you moneys worth from them. If I had bought the massive one, then the next day Id have gotten the fine wire one so really paid twice.
    I don't know if the fine wires are do expensive because of precision needed or the iridium metal.
    There's no evidence of anyone dropping my plug, it has been a year and 100 hours since the annual and was running fine. I didn't drop them or ovetorque them. As for as dropping, plugs are shipped in boxes and fed ex or ups or whoever drops the boxes. I have some doubts it the plugs are really that fragile. I have put a dropped one on the tester and it fired normal. I may send the plug to Champion to see what they say.
    Have you ever wondered why plugs come shipped like the do? In the protective container they come in? Even a quality auto plug will be protected in the box from such handling practices. Porcelain breaks very easy. The problem, when you crack the porcelain most time the porcelain will not come apart. It will hold together. Seeing how this porcelain is down deep in the plug you can not see this broken porcelain. Then under combustion pressure the plugs porcelain comes apart. The combustion camber is a very violent environment.
    I would want to know what caused the porcelain to break? In all my years I have never had this happen unless there was another underlying cause. Be it the plug was dropped, preignition..ect.
    Most common cause of porcelain fracture in service is detonation.
    Yes, the drop was just a guess as to "how could this have happened."
    1600VW is right about this. It's very hard to test for failure of these high tension insulators. And just because it passes after it was dropped doesn't mean it doesn't still have a latent defect that fails a time later.
    Fort Vermilion Alberta
    $140 for a spark plug!
    I am glad I bought Pmags and use $5 BR8's.
    Try gaping your massive plugs to .40 and get that old 1940 tractor mag to fire them.
