Hello does any members have any experience with the rib plans for the pober pixy, on the plans behind the rear spar on the 14 rib ( the full length rib it is hard to tell if the top capstrip is cut to accommodate the 1/4 x 3/4 flat that runs the full length of the wing or doe it butt up to the capstrip and then get a gusset. Also the 1/4 inch thick block that fits at the same point on the standard ribs,: the measurement on the plans would mean that the capstrip would end at the trailing edge of the rear spar however the pictures look like the blocks fit under the castrip behind the rear spar. can someone clarify this please.
