Corrosion X in building a metal homebuilt.
I am building a Windwagon/Hummelbird. The Builder's Manual for the Windwagon calls for the use of primer between pieces to be bolted or riveted. However this was written way before Corrosion X became available. Would the Corrosion X alone give the airframe the protection or should I still primer the mating surfaces.
