Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Ailerons: Yea of Nay
    cluttonfred's Avatar
    World traveler
    The Ercoupe has the traditional aerodynamic control surfaces that could control pitch, roll, and yaw if connected to conventional controls but without the rudder pedals the pilot has only two axes of control, pitch and "turn" (coupled yaw/roll). The effect is the same as a Quicksilver or Sky Pup without any form of roll control surfaces and just a rudder, but Ercoupe's coupled controls reduce the initial skidding before dihedral effect takes over in a turn.
    As I understand it the Ercoupe is a three-axis airplane, it links the rudder and ailerons to the control wheel instead of having rudder pedals (an optional accessory)
    Matthew Long, Editor
    cluttonfred.info
    Those yokes in Cessna 12/140's were the same but different.
    Aeronca Chief had that yoke also.
    Dec 2014
    Valparaiso, Indiana
    My first UL was a Quicksilver MX in the configuration that had the rudder on the stick and spoilers on the pedals. I'm a PPL and had to convert the rudder to the pedals to be comfortable. The spoilers didn't really do much, but if you normally fly coordinated then it will feel more natural. Crosswinds are a problem as the spoiler will not keep the upwind wing down. I actually landed across the runway several times. Not being able to handle much wind was why I sold the Quick and bought a CGS Hawk and got flaps in the bargain. So, with your GA experience I think you would be happier with three axis.
    World traveler
    Just as food for thought here are a couple of photos of a Criquet Leger, one of the designs by the late Emilien Croses, probably the best-known "disciple" of Henri Mignet, who put his own spin on the two-axis Mignet tandem formula.
    Name:  Criquet L 2013 1.jpg
    You can see here another example of a proven two-axis system. The wheels turn left and right to control the rudder, and they pivot on the bottom to actuate the pushrods that goes through the center hub to control the incidence of the front wing for pitch control. There are two pedals that you can just see but they only control brakes. The two levers on the side of the cockpit control tabs on the rear wing. They are are used together for pitch trim and differentially to dial in little bit of "aileron" when making a crosswind landing.
    Name:  Criquet L 2013 2.jpg
    I came very close to buying this plane in France back in 2013, I had actually rented a truck to go see it in person and bring it home, but I chickened out in the end as it needed some work and I was about to go overseas again. Side note...my son in the picture is now 15 and taller than me.
    cluttonfred.info
    If you do not have ailerons, wing dihedral is your friend.
    yeah, that yoke supplier was making a killing!
    My first flights was in a MX with spoilers. I found in a cross wind of 5 mph or less you could land this aircraft. To me this was a lot of fun.
