Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Non flying solo flight training via a Penguin
  1. #21
    cluttonfred's Avatar
    World traveler
    Here's an idea, a non-flying plane on gimbal so that you can get a feel for the controls while sitting on the ground. These days you could easily see using an electric motor and rechargeable batteries for power, maybe put a guard on the prop for to keep the lawyers at bay.
    https://www.facebook.com/FilmImages....4694061564805/
    http://www.messynessychic.com/2013/0...fayette-paris/
    Matthew Long, Editor
    cluttonfred.info
  2. #22
    Maybe the flight school should have a cheaper simulator so the student can sit there for five hours of rudder peddle practicing up and down the runway only without flight before moving on to actual flight.
    My brother had numerous dual lessons in our Chief, but just didn't get the hang of steering a taildragger. He wasn't that interested and gave up on flying
  3. #23
    Perhaps one that makes a raucous noise in the headset if the student doesn't put the proper wind inputs while taxiing.
  4. #24
    I just discovered this thread and we have been discussing the possibility of doing a Penguin as a youth build. It would also be a great recruiting tool for the chapter.
    Some of the possibilities, concerns, etc. are:
    1. Configuration- All Penguins we have seen photos of are tractors. Perhaps a pusher would be safer.
    2. It would be even safer if the prop had a cage like airboats use.
    3. There's concern that no amount of ground school would be equel to having an on board instructor. Therefor, how about a two place with the back seat on the C. G.?
    4. It would definitely not be capable of flight in any form. Not even short crow hops.
    5. Configuration again. If it was a pusher, use a three tube empennage system.
    6. From a cost standpoint electric is probably out as it would cost several times as much as using an industrial engine. That said electric would be cleaner and much quieter.
    7. For solo "flight" a remote (RC components) kill system is necessary.
    8. Folding or removable wings.
    9. Use a motorcycle front fork & tire for the wheel.
    10. Use wing tip wheels to reduce ground looping forces.
    11. Could be wood as the historical ones are, tube and fabric (a bit fragile) or aluminum. All would teach skills needed to build a real aircraft.
    12. The recruiting value for potential youth aviation candidates and adult EAA members would be tremendous.
    13. How would a chapter get insurance coverage for such an activity? If licensed pilots were used in a two place version, would the Young Eagles program cover it? If the Penguin weighed less than 254 lbs qualifying as an ultralight fit into the Young Eagles program?
    Any thoughts on this?
    Vince Homer
    EAA 292
  5. #25
    Jan 2012
    Quote Originally Posted by Vince View Post
    Vince Homer
    EAA 292
    Vince,
    I started this list several months ago and have had little positive response. My proposal does not conform to many of your concerns/requirements but I would be interested in continuing discussions as I do believe there are several benefits to the proposal and it would satisfy your requirements. email cfig1467368@yahoo.com for contact info.
  6. #26
    World traveler
    In these days of liability and lawsuits, I think an actual Penguin trainer would be a disaster waiting to happen. On the other hand, something like an adult-size toy plane on a gimbal with an electric motor and propeller up front that would give a little of the sensation of aerodynamic control could be a lot of fun. The old Link Trainers were actually quite complex electromechanical contraptions, but something more like the Paris rooftop one in my previous post would be quite doable.
    cluttonfred.info
  7. #27
    Sad to say, but you're correct. It would be a lawyer's field day. That's why we are checking to see if such an activity could be done under the insurance umbrella of the Young Eagles program.
    Vince Homer
    vhhomer@hotmail.com
  8. #28
    Jan 2012
    Vince Homer
    vhhomer@hotmail.com
    Any reply from EAA staff?
  9. #29
    No Reply
    Quote Originally Posted by jedi View Post
    It's been all quiet on the EAA Front.
    We had tried to compare it to the chapter owning an ATV and would a participant in the Youth Aviation program be covered riding it off road. It's a stretch, but we had to start somewhere and we did propose a two place Penguin with an adult pilot on board.
    Vince Homer
