Just to add another element to the discussion on TBO, there was a famous research scientist or engineer in England over the war that found in bombers, that the planes that were inspected more often were LESS reliable and less ready for duty. Thus, LESS NOT MORE, maintenance was better; sort of it it is running good it is better to let well enough alone.
I don't have his name now, nor more details. but I'd guess that one aspect of this was that if an engine was likely to have trouble it may do it early in its life, and once past a certain hours it is more likely to last longer if not disturbed.
This is not just theory, at least in the case I am reffuring to, the research was accepted by the RAF.
