Mediablasting service referral northern IL / southern WI?
Hi there, does anybody have a recommendation of a mediablasting company that would be skilled at blasting a steel tube fuselage frame? The fuselage is located outside of Freeport (IL), but I could transport it anywhere within an hour which would put Rockford and southern WI a possibility. I just want to make sure I get it done right without compromising the integrity of the structure.
Thanks!
